Heated Seat Problem
My drivers seat heat in my 03 Yukon quit the other day. When you press the switch to activate the lights come on for maybe half a second, the door module under the seat clicks and the switch lights go out. The passenger side works, but when you hit the drivers side switch i get the click and both turn off. I've seen the TSB on the seats about reprogramming the module and I don't think that is the problem as the memory / adjustable pedal functions work fine.
Before I purchase a new element for the seat anything else to check out? Is there anyone on here thats gone trough this before?
I for some reason remember someone posting a how to guide with pics of how to change out the element. I tried a search but could not find it.
Sounds like the Element....had a buddy that had an 05 Tahoe LT do this last year. We put a new element in the seat and all is well.
Hope this helps.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
