bss2692 Posted October 22, 2009 Posted October 22, 2009 Will try and keep it simple - short..and sweet (But i know it's not going to be short.) 2002 Silv - 1500 4.8L LS 140K miles. It is getting FULLY PAID OFF NEXT MONTH. Things GOOD: I've not had ANY, NONE Mechanical problems. I Change my oil about 4000miles. I replaced 1 of the 2(yes 2) CatConv. few years ago, and replaced the rear brakes @ 90K..and the Fronts @ 120K. THAT IS IT. Things I sorta(?!!) neglected: Original Fluids: DexCool ----> never touched it.. Rear Diff. -----> never had work on it (open, not locking) Trans. -----> never had work on it Original EVERYTHING: Sparks, filters (oh, have a K&N Stock Air filter that I occasionaly wash and oil) CHANGED Belts out @ 70,000 when my A/C compressor died. I think the serpentine is original still.. I dunno. So: (quit throwing tomatoes already ) What do you recommend? I now have some $$ that I can play with to fix it better to keep Longer.... But - it ain't Broke.... and you know how that goes... So - I Emplore each of you... to give me the TOP 5 Things I should do First: IN ORDER - and possible $$ we're talking here... no really, i haven't changed one fluid except oil. so wtf do you suggest?
txab Posted October 22, 2009 Posted October 22, 2009 DexCool. Include replacing all hoses, thermostat and doing a thorough flush. Replace the serpentine belt if never replaced. < $150 Fuel filter $10 Trans. and filter. Filter $25 or less. Fluid ? price depends on what you use Sparkplugs and wires $100 or less depending on where you purchase. Check ebay. Rear Diff. $ depends on your choice of lubes. Conventional or synthetic Power steering fluid. $ depends on your choice of lubes. Conventional or synthetic
cerbomark Posted October 23, 2009 Posted October 23, 2009 I agree with the above except maybe just leave the trans alone (the whole thing about changing the fluid at all after that many miles may cause the trans more issues) Look around and fix any leaks or broken thing you may find on the underside. And then drive it without payments and enjoy.
txab Posted October 23, 2009 Posted October 23, 2009 I don't think swapping out 4 or 5 qts of trans fluid in the pan will cause a problem. The maybe in a year he swaps another 4 or 5. One thing to check would be to see if you have an air filter for the heat/ac system inside. If so you may need to change it
bss2692 Posted October 26, 2009 Author Posted October 26, 2009 Good thoughts Guys! Thank you... Anyone Else got some Ideas on what to do? whther you agree with these - or have a totally Different idea of what to do...? and i AM Looking forward to socking some $$$ away.. Woohoo! but - i want to actually take care of these things before I get a set of tires... and run another 50K or so on it...
mercenarygod Posted November 8, 2009 Posted November 8, 2009 Definitely look for any leaks! and Flush that bad boy out with your favorite cleaners. Maybe a oil and fuel cleaner. There are many choices. and The first response nailed it, just don't forget to check for leaks.
MarkD Posted November 8, 2009 Posted November 8, 2009 I put a filter and fluid in my trans every 30k miles, and would recommend the same. I am kinda hard on my trans though, harder than most. I am just over 140k miles on an 03 5.3. It costs me about $35 I would have a shop flush/fill your brake fluid. By 140k you definately have water in it by now. I know brakes aren't "glamorous", but they are important $40-$50 depending on shop.
bss2692 Posted November 18, 2009 Author Posted November 18, 2009 NO MORE PAYMENTS ! Whoop ! Now that I got THAT out, I feel better. Anyways - All of these have been taken into consideration and really written done on a checklist for me to take care of in the next few weeks. It's not a Rush thing - but I'm looking to bust the 150,000 marker soon enough. Nice "anniversary present" for it. Now, to fix the cosmetic damage by the Horse Bite (yes, really) on my hood. and the DRL lamp Sockets that are burnt, cursty and don't even work at all..
