06 2500hd Trans Noise
snorydermb
Ive got a 2500hd crewcab and in first gear I get a howl or a whine noise coming from the trans or the transfercase it goes away as soon as it shifts into second gear any ideas what it could be.
thanks mike
I know exactly what that noise is .there is a bulletin for this very noise ,the fix is to take it apart ,check the end play at the bottom or rear (bottom on the bench clamp),if there is end play ,then you get a new GM rebuilt tranny,
thats it ,very simple ,I've done a thousand of them,
all the paper work is done to call in to PQC and puff ,a tranny overnight
you have a 5 yr powertrain warrenty or not?
if not ,don't go lookin for a part to replace 'cause GM dosen't know either,
I changed the gear set once and that didn.t fix it (before the bulletin)
so in short ,don't get it rebuilt,just shit can it
+1
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
