My brother-in-law has a 2002 silverado z71 with about 130000 miles. He brought it by today for me to listen to and its making a strange noise like a chain rubbing or something sounds like its coming from the transfer case.I had him lock it in 4 wheel drive and it it made a much worse noise. I wasnt aware that gm trucks have any trouble with the transfer cases i work at a parts store and havent ever heard of anyone having any trouble. Just wandering if anyone else has had any trouble or could give me some advice on how to proceed. thanks in advance.
I think there are several posts on this subject. Some people even had a problem with a hole being worn through the case.
130K is still a lot of miles. Who knows what the Tcase has been through. Might be time for a boneyard replacement with less miles on it.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
