Powering My Laptop In My Truck
Grip72
so i'm a consultant and i will be spending alot of time in my truck being bored out of my mind haha.
i have my trusty work laptop and a flash drive i can fill full of movies
i have a ac to dc convertor in the truck already that plugs into the cigarette plug but it only allows me to watch maybe 1.5-2hours worth of movies and my days will be 10hrs+
so,
what's the best way to get more life out of my laptop (besides running the truck, cause i tried that and would have to run the truck for probably 2 hours to fully charge the laptop again).
would adding a second battery benefit me at all?
The right adapter will charge your laptop whether the truck is running or not. You got something wrong.
You can run it all day off of the truck battery with the correct adapter.
C
it's a power convertor, not an adapter. it's not specifically for the laptop, it'll power any household 120v item.. would an adapter designed for the laptop be better?
You mean DC to AC inverter?
If you purchase the specific car adapter for your laptop that would be the best option. It would be a DC to DC change, which is better than going DC to AC back to DC. I would estimate around $60-75 for the laptop's manufacturer's price on a car adapter. I would start there.
I would purchase an AC/DC inverter. Wire it directly to the battery with a solenoid protected switch. A small 100w inverter should work. My dell uses a 90 AC power cord.
I had big problems running my laptop through the cig lighter.
I've run an inverter in my company car with my laptop plugged into it for years. It'll run for hours without the engine running and have no effect on the battery. I use it every day... plus it sharges the laptop battery.
im going to need to do this soon, and have always thought that a power inverter takes up a lot of power, i am going to see if HP has a car charger for my laptop
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
