2007 Silverado Z71 Passenger Power Seat
Have you ruled out all other options before the motor? wires? fuse? relays? even the switch?
I would hate to see you replace a good motor because of a bad switch/fuse/relay/wire. I once replaced window motor just to find out the swtich was bad because someone who will go nameless left the window down in the rain.
  • 4 months later...
i have checked everything and all power leads to the motor, any one know the part number or how to remove the seat?
Typically, there are four bolts holding the seat frame to the floor board. Two in the front and two in the back. On my '06, they used a special star head bolt, requiring a proper size star socket. But I found out that a regular correct size metric deep socket works on those also.
