2008 Gmc Schematic
gagd03
Hi,
I've bought a Suburban 2008 radio to replace one in my Savana. My problem is that is not the same connections; actually, just 1 connector and on new radio, 2 connectors
I don't want buy service manual of Suburban just for this schematic. Some want could help me?
I know also that I will need my dealer to unlock the radio, but if it's already connected, I will save money!
thanks for your help :D ,
Dominic
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
