Throttle Body And Top End Cleaning
A few years ago I was complaining to a GM Service Manager about a sticky throttle on my 2000 Silverado 4.8l? I can't remember the name of the stuff I bought from him, but I think it was something like 'GM Combustion Chamber Cleaner"? I don't think it was GM Top End Cleaner. Anyways, he recommended to pull the air intake off the TB and to spray in a whole can of the stuff into the TB, washing the TB and throttle plate while holding the throttle open to keep from stalling.
I plan on doing the same for my 2005 and the manager (whom I respect and trust) is retired and not around to ask what to do anymore. So I wanted to know what's the current accepted practice for TB and top end cleaning (never did the later on my 2000). Some of my questions/concerns are....
- What do I use? GM Top End Cleaner, Combustion Chamber Cleaner, Sea Foam Deep Creep....etc?
- Is hydraulic lock a real concern? I sprayed in the whole can of the GM Combustion Chamber Cleaner in my 2000 with no problems other than white smoke. I'm think I sprayed it in all at once rather than in short bursts.
- Is there a TSB on how to do this and with what? I think there was for my 2000.
Thanks :lol:
The only way to really clean the TB is to remove it. Then take off all the sensors and libberally spray it down with TB cleaner. I either scrub it with a old toothbruck or rag to get all the deposits off.
Yeah, I've noticed a few people say that. Is there a "How To" on this? Probably pretty straight forward, but nothing like having some tips and tricks.
Lets see....
Vehicle is turned off.
Disconnect neg batery cable. ..or your supposed to.... :lol:
Remove intake from TB.
Disconnect connector from IAT and TPS
Disconect throttle cable or disconnect DBW connector
Remove coolant bypass hoses. (Can get messy)
Remove nuts/bolts holding TB in place.
Remove gasket ,Try not to damage the gasket while the TB is off.
Remove IAT and TPS sensors from TB. (Should be 2 screws for both)(I always kept them in and crossed my fingers)
Spray cleaner and scrub if necessary. Reinstall in reverse.
off the top of my head, that should be the just of it.
Awesome - what do you use for "spray"? You can't use carb cleaner, right?
I use Seafoam's Deep Creep cleaner. (10 bucks at an auto parts store). It worked well when I cleaned up my TB.
Thanks :lol:
Get some throttle body cleaner from you local auto parts store, remove the air intake, open the butterfly and spray the shit out of it. If it's that gunked up use a rag to clean it out. I've cleaned mine a few times like that and it works just fine. No need to go through all of the trouble of removing it. BTW, your 05 shouldn't gunk up like the 00 did.....GM reworked the PCV system somewhat.
Good to know.
Honestly, I haven't pulled the air intake off yet to look at the TB. I've just noticed that the acceleration was kinda sluggish compared to my old 4.8 (2WD) and other 4.8 and 5.3 4WD's I've driven. Has 94,000 miles on it, so it shouldn't really be that tired yet. So far I've just changed the plugs. After I clean the throttle body, I might do a top end treatment (Seafoam) or get a top end/fuel injector cleaning using the canister that hooks up to the fuel rail.
Thanks :lol:
Occasionally you may need to remove the TB to do a more thorough cleaning. There is buildup that you don't get by just hosing it off from the outside.
"Occasionally you may need to remove the TB to do a more thorough cleaning. There is buildup that you don't get by just hosing it off from the outside."
Yep, same with me.
I don't have a true schedule to do an "off-truck" cleaning.
It mainly has to do with how bad it looks after so many of the "quickies" and if I have enough beer in the frig for the project.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
