Drone Rattle @ 1400rpm Stock Exhaust
I was having noise with my cats and those are now replaced but I now hear a drone about 1400rpm with no load. It sounds right under the middle of the bed its very irritating. The entire exhaust is all new its a 2003 1500HD with 60,000 miles. It only seems to make this noise when warmed up. I read one post about the drive shafts making a drone vibration being hollow aluminum, could that be the case? Id think the issue to be simpler with just some shield vibrating against the cabin. I cant seem to find anything under the truck and just revving the engine will not reproduce the issue. From a stop sign accelorating slowly to around 25 you hear it pass though that droning range, you can also slow and drop right into the area and make it resonate as well.
Thoughts?
I was having noise with my cats and those are now replaced but I now hear a drone about 1400rpm with no load. It sounds right under the middle of the bed its very irritating. The entire exhaust is all new its a 2003 1500HD with 60,000 miles. It only seems to make this noise when warmed up. I read one post about the drive shafts making a drone vibration being hollow aluminum, could that be the case? Id think the issue to be simpler with just some shield vibrating against the cabin. I cant seem to find anything under the truck and just revving the engine will not reproduce the issue. From a stop sign accelorating slowly to around 44 you hear it pass though that droning range, you can also slow and drop right into the area and make it resonate as well.
Thoughts?
Is the "new" exhaust a factory replacement or aftermarket? The 6.0 engine is known to produce a drone in the cab right around the rpm you describe with some aftermarket systems.
Mine did something similar, especially with the A/C on. It was the heat shield on the muffler. I took it to a muffler shop and most of the tack welds on the shield were cracked or broken thru.
Thoughts?
The exhaust is all straight from the bowtie boys. All oem.
Mine is completely stock as well, check that muffler heat shield, mine barely moved but it droned exactly like you described, once the tack welds were repaired, I was amazed at how much noise I had gotten used to hearing, it was nearly silent!
GM has a fix, there is a steel band that re-attaches the heat shield and stops the drone. There's a TSB on it so I guess it's a common problem.
you have tsb number?
I placed 2 ss pipe clamps around the heatshild and muffler, seemed to have no effect. The new muffler also looks different than the old, it has 3 bands around it already I wonder if its a new design since 03. I looked at the tranny shield it was all tight and not touching. Everything else looks fine under there.
I wish I could see somthing hanging loose or cracked. Anymore thoughts?
*Update*
I played with the noise and cant repro when in neutral but I can repro when in gear with the brakes on and taking the RPM to 1400. That seems to indicate not an axel-drive shaft issue plus now I can have a helper isolate where the noise is origionating.
The other option was to get somone like SnakeEyes dragging underneath the truck :lol:
I got the opportunity to crawl under the truck with my buddy power braking it @ 1400. Its the entire exhaust system resonating. I couldnt stop it with just my hand on the muffler, it took a foot on the muffler and a hand on the cat.
My idea was to heat up the system (drive around) loosen the clamps, get it vibrating again, then retighten them.
Any other ideas?
#PIP3121E: Exhaust Vibration, Resonance or Moan - keywords 4.8L 5.3L 6.0L A/C acceleration air conditioning fluctuation idle intermittent L59 LM7 LR4 LQ4 LQ9 moan noise resonance rough vibration
    Tbhats2130
    Tbhats2130
  • Who's Online   3 Members, 0 Anonymous, 1,239 Guests (See full list)
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
