Towing Mirror
im looking for a set of towing mirrors for my 2007 1500 does anyone know who has the best deals on them. thanks in advanced
I have a set that I took off my 2005 Silverado, the right side is perfect. The driver side mirror shakes a little when you have it at a certain angle at highway speeds. If your interested, PM me. I packaged them up, put them in a box, and put them in the attic when I took them off, so they are ready to go.
Thanks,
Randy
Thanks,
Randy
will they fit a 2007 new body style? if so pm me the price. thanks chris
Thanks,
Randy
I don't think so, :P They will fit the classic style, and they will fit on your truck, but I don't think they will look right. If you hear of any body looking for some on the older body style, please let them know.
Have a good one! :rolleyes:
I would say his 05 would not fit your 07, mirror is a bit different.
I have that brand that was posted above on my 06...over all I like them, they look factory and are easy to install and remove (once you get the hang of it). The drivers side mirror does seem to shake just a bit for some reason...but not so much that I don't even notice it after a while...unless I stare at it... :rolleyes:
you could also get factory mirrors that someone else took off there truck, if you have power mirrors already you may have to get them reprogrammed from gm to control the power for the mirrors expanding in and out from your mirror switch if you get mirrors that have that option. if you get ones with the integrated turn signals on them and you didnt have them on your oem mirrors they should still work without reprogramming, at least that was the case on my 06 sierra, i ended up taking mine off anyways cuz the shaking mirror annoyed me so much.
i would like to get a set of factory tow mirrors if possible i heard that the clip on style shake and awful lot
Ebay should have several options for you.
I'm going with this style Personally.
http://cgi.ebay.com/ebaymotors/MIRROR-07-0...d=p4506.c0.m245
I have seen those too. Anybody used them already, I have seen them at Canadian Tire, if I factor in shipping and exchange, it's close to the same price as on eBay.
On my previous TV, I was using the one that sit in the window sill and strap to the bottom of the door. I can still use those, but they are ugly as hell.
And I don't want to replace my factory mirrors because I'd loose the power folding.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
