Removing Warn Locking Hub
I'm trying to change my brake rotor on my 83 gmc k1500 and cant seem to figure out how to remove the warn locking hub to get to the nut for the rotor... any suggestions?
There should be allen head screws around the outer edge of the hub.Take those off,the hub will come off with a spring inside. then you will see the nut,you will need to bend the locktab and use a socket that has teeth to remove the nut
