JP Customs Tailgate Lock
Product Name:  JP Customs Tailgate Lock
Manufacturer: JP Customs
Purchased at:  JP Customs
Cost:  $35.00
Skill Level:  Easy
Overall Rating:  9.0
I like this lock.  It's got a nice OEM look.  The parts look durable.  If you've got a spray in bedliner like I do, it's a bit more difficult to get to the bolt on the inside of the tailgate.  In my case, I grabbed the bolt with vice-grips and worked it out enough that I could cut the liner around the washer with a utility knife and remove it cleanly.  Also, the placement of the pivoting part requires that you pay attention, but it's easy to install.
I think the end product looks nice.  It works very well.  A determined theif could probably defeat it if he knew how, but that's the case with just about everything.  I would recommend it.  I like it better than the plate that went over the lock on my 95.
  • 3 months later...
This lock from JP Customs is the BULLY Lock available from Pep Boys for $19.95 + tax.
I agree the lock takes some time to install, but I found the problem, not with my Line-X bed liner but to keeping the lock straight (has a spring loaded lever) against the tailgate to line up the screw.  But then again I installed it at 10PM with hardly any light and going by feel.
The lock key is of similar length as the door/ignition key, (haven't checked yet) so the lock might be changed with a GM lock and keyed to the door key for maintaining a one key system.
For the price to prevent casual tailgate theft and not having to drill a hole and place a bolt over the right hinge I give it a 9.5
If you pay $35 I would say it only would rate about 8.5 for the money.
  • 2 years later...
I also bought one of these from JP Customs recently (got it through them because I was ordering some other stuff anyway and decided to get as much as I could from the same place). I like the "factory" look of the Bully lock, and if I can get it rekeyed to fit the factory truck key that'll be a nice bonus. I haven't looked into that yet though.
