Rear Defroster Cable On 2007 Tahoe
I've got a 2007 Tahoe and one of the cables to the rear defroster came off where it attaches to the window.
Will the GM extended warranty cover this repair? Dealer is saying no, because they classify it as part of the glass. Personally I think that is BS.
Can I do it myself? It seems like the cleaning would be the hard part.
What type of adhesive is it?
Any advice from the GM experts out there? Thanks!
This might help you..
#03-08-48-006F: Repair Information for Reconnection of Rear Window Defroster Contact or Tab - (May 26, 2009)
Subject: Repair Information for Reconnection of Rear Window Defroster Contact or Tab
Models:
2000-2009 GM Passenger Cars and Trucks (including Saturn)
2003-2009 HUMMER
Equipped With Electric Rear Window Defroster -- RPO C49
Repair Suggestions
Soldering Defroster Contact Tabs
In many cases the terminal tab will still be in the connector when you examine the vehicle. For Chevrolet Tahoe, Suburban, GMC Yukon, and Cadillac Escalade vehicles (with moveable glass), always replace the defroster tab (GM P/N 25916031) and the defroster electrical power connector (P/N 12034110). For all other vehicles, reconnect the original defroster tab.
In most applications it is preferable to create a new solder connection to reattach a separated rear defroster tab. If you take note of the steps below, it is possible to create a new solder joint that is equal to, or stronger than, the original. The generic procedure below is not very time intensive, but does include minor preparation work to create a good bonding surface. Be sure to follow each of the steps, as combined they will produce the strongest bond possible. Please consider the following before attempting the repair:
• Soldering introduces significant heat to the glass window of the vehicle. When performing the re-connection of the tab, use only the heat required to do the job. Pre-heat the soldering iron and have the solder in your other hand, ready to go, the moment you have enough heat to melt the solder.
• If it is winter, bring the vehicle into the service garage and remove any snow from the back window area. Allow time for the glass to warm to the temperature inside the building. Soldering creates a "hot spot" in the glass. DO NOT solder on cold glass.
Caution: Heating the glass excessively, or repeatedly without time to cool, may result in glass breakage. ALWAYS wear safety glasses when performing this repair!
• You MUST use a silver-bearing solder to make the connection. DO NOT attempt this repair with conventional tin/lead alloy solders. Silver bearing solder will adhere to the electrical buss bar, making a strong and lasting repair.
• Protect surfaces under the area to be soldered. It is very easy to drip solder when performing this repair. Pacing a shop towel under the soldering area is sufficient protection.
Soldering Procedure
It is imperative to remove and replace the rear defroster electrical power connector by crimping a new connector to the feed wire. The proper connector P/N 12034110 can be found in the Packard Electrical Assortment, Tray 18, Position 5.
• Insert Delphi pick 12094430 to depress the locking tab on the terminal.
• Insert Delphi pick 12094429 to release the secondary lock tab.
Important: DO NOT re-use the existing defroster tab on new-style full-size utility vehicles with moveable glass.
Connect the electrical connector to the defroster tab. Fully engage the connector. An improperly seated connector may cause excessive resistance and impede the proper operation of the defroster. Add a small bead of solder to mate the electrical connector tab to the defroster tab.
Prepare the surface of the used defroster tab (not required for new tabs on new-style full-size utility models) and the defroster buss bar with fine grain (500 grit) sandpaper or Emery cloth. It is not necessary to remove all of the original solder, but it should be scuffed sufficiently so that no oxidation is present. The photo above shows a close up of a properly prepared surface.
Tip
You may want to mask the glass around the contact area with tape. This is easy to do and will allow you to safely prepare the contact surface without the risk of scratching the glass or the black painted shading.
Important: Most rear glass has a black painted masking around the edge of the glass. When cleaning up the connection surface, be very careful not to damage the surface of the black shading or the surface of the glass.
Wipe the newly prepared contact area with Kent Automotive* Acrysol™ (or equivalent) to remove any residual oil or dirt.
Important: You MUST use a silver-bearing solder to make the solder joint. DO NOT attempt this repair with conventional tin/lead alloy solders. Most suppliers have this type of solder available and it is available nationally at Radio Shack®*. It is sold in several diameters and either are acceptable for this repair.
For this step, it is permitted that two technicians be used if required. Heat the new connector on the surface of the buss bar that is to be soldered. Long nose pliers are suggested to hold the electrical connector and the defroster tab in place. Keep the solder ready and begin flowing out the solder as soon as the melting temperature has been reached.
Tip
If a single technician is attempting this repair, it is beneficial to wrap one turn of the solder around the new contacts base. In this manner, as the melting point of the solder is reached, a layer is deposited on the bottom side of the contact.
Important: Try to align the new contact so that it is positioned with the same orientation as the original contact.
Additional stray solder will not harm the performance of the bond; however, while it is unlikely that customers may refer to the appearance of the rear window defroster and its components as a positive styling feature of the vehicle interior, it is easy to elicit the opposite reaction due to a poor cosmetic application.
*We believe this source and their products to be reliable. There may be additional manufacturers of such products/materials. General Motors does not endorse, indicate any preference for, or assume any responsibility for the products or material from this firm or for any such items that may be available from other sources.
Parts Information
Acrysol™ can be ordered directly from Kent Automotive at 1-800-654-6333 (in Canada, 1-800-563-1717).
Radio Shack® products can be found nationally at retail locations, www.radioshack.com, or at 1-800-843-7422.
In Canada, use The Source by Circuit City™ -- www.thesourcecc.ca or telephone 1-866-454-4426 (for English) or 1-866-544-4431 (for French), or at an equivalent retail location.
All other parts can be ordered through GMSPO or SSPO.
Part Number
Description
25916031
Tab, Defroster Power (new-style full-size utility models)
12034110 (Tray 18, Position 5)
Rear Defroster Electrical Power Connector (Packard Electrical Assortment Only)
64-013E*
Radio Shack® Silver Solder (0.22 dia)
64-026E*
Radio Shack® Silver Solder (0.62 dia)
P20005*
Kent Automotive Acrysol™ Solvent (32 fl oz) 946 ml
12377900* (U.S.)
10953529 (Canada)
GM Vehicle Care Dielectric Lubricant (2 fl oz)
That sounds like a bs excuse to me that its not covered because its part of the glass. Absolutely awful in this market when they should be trying to retain future customers.
I would try a different dealership and see if they can pursue a fix with the info posted above.
  • 1 year later...
I'm on my 4th glass window in the rear. GM keeps replacing them so I'll keep taking them. Wire/solder came off again about a week ago. Their solution this time is to solder it back on. I made certain they have another glass ready for when the inevitable happens - they shatter my rear window. A customer at the dealer is on his 8th (!) rear glass. On the other hand, my brother's Denali is on it's original glass still. (08). Go figure.
Svc. Mgr. told me GM is aware of the problem and is close to issuing a recall on the glass. I can't possibly see how they are going to keep up with that demand.
Had a tab fall of after primary warranty. I have a 100K extended. First time they tried to re-solder it. It held for a few months. Second time they re-soldered it. Held for another few months. Next time they willingly replaced the rear glass at no cost to me at about 50K miles. The rear glass is OUTRAGEOUSLY expensive and is actually glues on to the hinges. Catch a nice buzz if you hang out in the back after they install it as the glue gives of some strong vapors :lol:
  • 8 months later...
I'm going in for my 4th cable and/or rear window replacement on Monday. I've had 1 cable re-attach and two entire new rear window replacements (all under warranty so far). The new rear window cables came off after two weeks! We rarely open the top hatch in an effort to protect the cables...no matter. Horrible design flaw.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
