Carbon Fiber Dash Kit
Who has put in a carbon fiber dash kit? I have saw the CF black/orange and think it might be ok, orange being for Allis Chalmers. I only saw that color at one place.
I would like to see some dash kits installed too. I bought a titanium burlwood kit (looks like black marble), but have yet to install it. I'm still on the fence on whether or not to install it. It will definitely break up the blandness of the dash, but I'm afraid that it will look cheap/cheesy. Another reason I'm hesitant is because it's a mod that cannot be easily undone.
