Does Anybody
I did search first and could not find what I wanted.
I'm looking for pictures of 2008 Silverado Crewcabs with leveling kits (2") on STOCK 20" wheels.
Please post if you got them.
Here is my truck. As far as the leveling kit goes, I have the RC 2" kit, but I only used 1" of it since I bought the adjustable kit with the 3 blocks. With the 1" I am almost level, with a slight rake which is what I wanted for when I tow a trailer. I think if I had gone with the full 2", I would have had a little cali lean to it.
Does it ride any different after you leveled it?
Still rides like stock. You will need to get it aligned once you level it, but after that it's fine.
Thanks Mossyoakglock! Been wanting to do this myself just heard that it handles better in curves just a little bumpier on our wonderful roads.
mine's an 07 but essentially the same..
side:
front:
this is with a full 2" rough country leveling kit (link is in my sig)
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
