99 K1500 5.7 350 Sub Intake Torque?
i have a 99 k1500 Sub with a 5.7 350, the motor died, i replaced it. and since the chilton's book from 98 doesn't actually describe the intake, and the 99 book doesn't even list the 350 as a possible motor, i was wondering if anyone knew the actual torque for the upper and lower intake manifold (followed the 98 book and squished the plastic around the bolt holes on the upper intake) and sequence. thanks much ahead of time
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 999 Guests (See full list)
