Anyone Supercharge A Sierra Denali?
I have owned two supercharged for trucks and I can say traction is the major issue, especially with such a light bed. It occured to me since I bought my Denali that if someone would supercharge the AWD Denali, it would be incredible. Do you guys know of anyone who has done this?
Tons of Silverado SS guys have put S/C's on their AWD SS's, nothing new.
its quite common, but pricey, i'd be very scared putting that much nuts on a rear wheel drive only though, so awd is a must i'm sure
I've done it (not on a Sierra Denali, but other trucks). It's not as bad as you might think. Great thing about a 2wd full size truck is that the sky is the limit on rear tire widths.
If I finagle, hammer, beat, pry, and get PERFECT offset wheels, I might be able to get a 295 on the rear of my GTO. That aint shit really. You can slap some 345's on a pickup though, as long as you don't mind how it looks :lol:
I'd love to have a Sierra Denali AWD with a supercharger.
I had 305's on the back of my lightning and it didnt help, at the track I ran Hoosier slicks and I still had trouble launching so I think AWD is a must if it is optional.
What kind of power are the SS putting to the wheels with a supercharger? How do you dyno a AWD truck?
Find an AWD dyno or remove the front driveshaft.
Can you do that on a Sierra Denali? I don't know what kind of transfercase/center differential they use. I know a couple of guys that tried on the TBSS's and it started breaking stuff.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
