Odd Vibration?
jro909
its around 0 degrees here and when i start my truck to idle, i get this pulseing vibration until the truck idles down to 500 or warms up then it goes away, what could this be? this vibration i can feel in the cab...
Its cause your rubber isolation mounts...engine mounts and trans mounts...are more like rock than rubber at 0*F...thats too damn cold man...glad I'm not where you are.
+1
I have felt the same vibration when the temp gets down low.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
