I have a 06 chevy silverado 1500.(2wd by the way, which was a MISTAKE)anyways.. a couple weeks ago my heat was working great, then one day it didn't even turn on. A few days ago, it turned on fine, worked amazing.. This morning when I got in my truck in the negative 10 degrees.. NO HEAT.. if you know what this might be, please let me know.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
