Torque Management.
The CTS-V has 556 HP and 551 LB/FT torque. Also 6l90E auto. Why should GM torque manage trucks with basically the same tranny when none have this much torque.
Not the same transmission and the V is a manual 6 speed. But there is TQ management in the CTS as well :uhoh:
The car has both, a manual and auto. What is different about the 6L90E in the Caddy and the 6L90E in the trucks?....The curb weight is 4200 pounds for the manual model and 4300 pounds for the optional automatic transmission models.
I don't know of any truck with 500+ TQ running a 90e? Which one are you referring to? Most have the 60e or 80e and a few with 65e.
Sorry, I got this cleared up now. I got some wrong info. The 6.2 in the trucks have the 6L80E.
All the 2500 and 3500 gas-motor trucks are 6L90....same basic box (inside) as the CTS-V auto from what I can find. The 1500 trucks use the 6L80 which is the same box (inside) as the Vette, the (dead) XLR and (dead) XLR-V, the V8 Camaro, etc.
I've heard that the TM is for lots of reasons...not just for the trans. I know there's a little during shifts to smooth things out a bit but I doubt that this is what most here complain about (go drive a carb'ed 4L60 from the late 80's early 90's and feel how much 'push' feel there is at the end of the shift compared to new stuff).
  • 1 month later...
Driveline torque depends on torque available, or skid torque, whichever is greater. Heavier truck has a higher skid torque so higher driveline torque. The CTS-V with 2200 lbs on the rear can't put that much torque to the ground in lower gears. A truck with 5000lbs on the rear axle may.
I have not seen anyone mention the fact that trucks are actually made for hauling and towing. When was the last time you saw a Cadillac tow something or haul lumber from the hardware store?
A truck towing 5000# or hauling some weight will naturally be harder on a transmission than a car of any sort.
For the record the 6L80e is also used in the new Camaro's w/ 426hp.
It would stand to reason that a transmission is at its weakest during a shift. Therefore it is beneficial to the tranny to limit input torque during this operation.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
