Oil Pressure Readings
Mine:
Cold at start up (45 degrees) 45 psi
Warm 45psi
At idle about 35psi
The pressure never seems to go above 45psi even if I get on it. Is this normal?
43 views?
Mine:
Warm 45psi
At idle about 35psi
43 views?
Normal, mine runs 45 on highway warm, 30 at idle, cold 45-50 idle. wouldnt worry
My '04 only has the gauge, so the pressure reading's are approximate. Mine is usually around 40 when cruising down the road. With a heavy trailer on the back, you can watch the gauge go up and down when accelerating.
The engine has an oil pressure regulator that will only let the pressure get up to a certain point and then it will open and the pressure will top out. The oil will be thicker when cold and thinner when hot so the pressures will be different with oil temp. Sounds like you have nothing to worry about.
Mine floats around 40 at idle and press the gas and get the RPMS at about 1200 and its 60...... My truck had got to where it would be 60 off idle till I stopped at a red light and then it would stay at 40 regardless of RPM. Flushed the engine with some engine flush ran it about 10 minutes on fresh oil and new filter. Dumped the oil and filter. Put a new filter on and 6 more quarts of syntec 10w30.... Took 2 times like that of changing the oil and my pressure came back.... (on the 10 minute run i just used regular castrol 10w30).
Be careful if you have never flushed a engine. You can cause problems QUICKLY. The flush breaks loose stuff that you would have swore was not in your engine and sends it to the oil pump screen and pump. If the oil pressure starts dropping. Kill the engine..... Drain oil, change filter, and refill. Crank if oil pressure does not return. Pull the pan and clean the oil screen. Refill and try again.
I have started a regiment of 1/3 can of Seafoam in the engine and about 5 minute drive then change the oil and filter.
Jbo
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 607 Guests (See full list)
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
