Hd Fog Lights, Really
i was messing around with the fog lights one morning. i would really like to know why they even bothered to put them on there. i turned off my head lights and kicked on the fogs. i had more light off of my running lights than the fogs, they did throw a beam to the sides but nothing to the front.
so what is the buzz for these nonprojecting over rated lights?
Like many things, they are a placeholder for a higher quality aftermarket upgrade. Bulb change at the very minimum, and housing change if you want to step up the quality to HID bulbs.
Yeah they are useless.
What are the upgrade possibilities?
Depends on which housing you are talking about and what type of bulbs you can run. Plus you need to determine whether you want to use them as fog lights or driving lights. My NBS Z71 can fit a round PIAA fog light housing in the valance perfectly, and due to their internal construction (not plastic) HIDs become a possibility. Sylvania SilverStar Ultras are a nice step-up in brightness at the expense of shorter longevity.
They are there for everyone who likes driving around during the day in a bright sunny day and at night where it's clear.
and they dont do a dam bit of good in any of them conditions, hell i dont think they would work in the fog.
i think the truck looks good with them on (at night) but they dont offer any more lighting. maybe ill see if i can find a brighter bulb. im not really in the mood to buy 200 dollar lights to look cool
All any fog light on any car has ever done, at least here in Southern California, is be turned on for driving around and blind every other driver on the road. I think I'm going to readjust my headlights so they are aimed as they were right after I leveled my truck.
    250.3k
    DjmFingerstylePlayer
  • Who's Online   4 Members, 1 Anonymous, 710 Guests (See full list)
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
