Glove Box Repair (need Help With Rivets)
The glove box latch on my 2003 Silverado rattles, so I'm going to replace it with a new one. However, I want to transfer my RPO sticker to the new glove box. I will need to drill out the rivets used to attach the panel that the sticker is on and re-rivet it to the new glove box. I've never used rivets before so I guess I need a rivet gun? I've listed the specs of the rivet below. Can someone show me the right rivet gun I need to install them? Also, what size drill bit should I use to drill out these rivets? Thanks for your help.
GM Part# 09442974
RIVET, 3/16" X .544 STYLE 1C, .424 LG., 34 OD, AL, PL, .062-.25 GRIP
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
