Wheel Sizing Help
Redneck56
I'm looking at getting a set of KMC rockstars for my 09 silverado 1500. I just dont know anything about wheels or tire sizing. I want a set of 18" wheels so that i can just use the stock tires i have on now. the truck has less then 1500km on it. all the wheels are 18 x9. will the stock 265/65R tires fit these wheels? also what bolt patren would i need. 6x139.7 or somthing? and what about backspacing i hate wheels that stick out past then fenders will these wheels do it with 0 offset and 5 backside. heres the site i got all my info from if you need to have a look to see the other options are. also can i put TPMS on these wheels?
Thanks I'm lost when it comes to this stuff.
http://www.wheelpros.com/browse.asp?page=d...&section=XD
Your stock tires will fit on 9" wide wheel. The lug pattern is 6 (no. of lugs) x 139.7 mm (5.5 bolt circle). I would recommend you google what information your looking for. There is plenty of information that explain what the terminology means. There's nothing wrong with asking for help, but the best satisfaction comes from educating yourself. Google wheel backspacing and offset, contact the wheel rep and ask about using tire pressure sensors, etc. You'll be glad you did.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 222 Guests (See full list)
