Aftermarket 2-way Remotes That Support Factory Remote Starter?
timmerk
Anyone know if these exist? I'm looking for a 2-way remote system (not GM's) that uses the actual factory remote starter option to start my truck. Basically I'm looking for a remote starter system that interfaces with trucks that are advertised by GM as being "remote start ready".
Any DEI system with the 1701G interface module. I've got the 5901 with that module in my truck. As far as I know its the only module that interfaces with the factory remote start. I used my to control the the power mirrors but for a normal install you only connect 3 wires to the truck. All the other wires connect between the two modules so you can do it on your workbench. I can post up a how to if you want that shows how to do the wiring.
The purple bundle is for auxilary controls, the two green are for my power mirror mod, the brown is for the aftermarket siren (didn't use), red to power, ground, and the single green wire goes to the low speed can bus at the OBD connector
I wanted to do the same thing, but after looking at the price of the alarm system, if was cheaper and easier to get an alarm system that included the remote start feature. Techs in my are did not want to deal with tapping into my stock remote start unit.
  • 4 months later...
Did the how to ever get posted? I'm very interested. Also was this just for "remote start ready" truck or would a truck with OEM remote start be this easy as well?
A DEI system with the 1701G module will be very easy to do. Most of the wires that come from the alarm go to the module. About 7 wires (including the ground and power) go to the truck. Very nice system.
I have a new GM Sierra with NO remote start. I was looking at upgrading to a factory OEM remote start...why is going aftermarket better? Range? Are the OEM starters short in range? Opinions?
The range on OEM remote start sucks. I tried to start my truck from across the street a few days ago and it wouldn't start. In addition there are some pretty cool features out there from Viper like the remote start from blackberry or iphone.
I agree, I have a Viper 5301 in my truck, and my dad has the factory in his 08, and his range is mediocre at best, mine blows it away, plus you can get a 2 way system, without having a huge remote with lcd. Also a Viper (or anything else DEI) is probably cheaper. I would highly reccomend the Viper 5101 or 5301, that is the 1 way and 2 way. I had the 1 way bought, and when I took it in to get it installed the 2 way was on sale, so I upgraded, and boy am I glad I did. I can start my truck, check the temp and check to make sure I locked the doors from wherever, inside the house, work, or at a restraunt.
I was quoted $350 installed for a factory OEM remote start with 1 keg fob...can I get a BETTER aftermarket remote start with more options for cheaper AND with 1 key fob???
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
