305/50/20 On Level Truck
jsciaretta
Would 305/50's fit on a my sierre. I currently have a Rough Country 3" lift with 275/55. Im looking to go a little bigger and wider. I know 305/55 will not fit, i know 285/55 will but they are outrageously expensive for that size. I can get general grabber at2 in the 305/50 for 200 a tire. Thoughts?
I will check it out.... I have a 3" lift it sits just about the exact level of the 2500hd or maybe higher.
I have the factory wheels. I believe its somewhere between 5.5 to 6.
I was told the 285/55 would fit the stock wheels. They avg 11.75 wide the 305/50 avg 12.4 wide so its a little more than a half inch. I would really like to run the 305/55 but those are 33/12.50 and from what im seeing even with my lift i cant see them fitting with the stock wheels....
also would a 275/65 fit. They measure 34/11.30..... i would be close on the diameter but the width stays the same as the stock 275/55...
Im tryin to either fill the wheel well or put a nice set of wider tires on it. I cant have both unfortunatley...
The thing you have to remember, is the closer into the wheel well the wheel fits, the more room you will need for that wide tire to clear. My wheels are 6.12"bs on a 9.5"wide wheel, and I did have some rubbing on the inner fender when wheels were at a full crank. I had the shock bolts flipped immediately, as I could see them rubbing the tires in the rear as well.
08 Blk GMC sierra crew cab 2wd
2.5" CCM front level kit
Blk RBP 94's +10mm offset with machined face... wheels about flush with the widest top portion of fender
Cooper zeon ltz 275/60/20
A wheel store guy tells me 305/55/20 A/T would fit without rubbing... Hummm well maybe with the factory +35mm offset? Who knows.... I think the 285/55/20 would be a perfect size, but it's only in nitto 10 ply for a grip of cash, if you want all terrain tire. Well with my +10mm offset wheel, I'm about 3/8" (measured) from rubbing on inner plastic while turning, with the 275/60/20. I would say 275/55/20, or 285/50/20 would be a safer bet. Both a tad bit wider, but 1" shorter. I read and investigated for about 3 weeks, and determined everyone had their own opinion on what does/does not work. It appears if you don't want a lifted truck (other than 2.5" leveling kit), and dont want to cut or modify, stay close to factory offset, and stay in the range of 32" high, and no more than 12" wide... On the conservative side, I would probibly go with 275/55/20 for my next tire due to my rim offset. If anyone has the Cooper in 275/55/20, and wants to trade the 55 for the 60, I only have about 50 miles on the tires (2 days old). I hope my research can be helpful to someone...
i would like to get 285/55 but i do not want to spend 1500 in tires. 305/50 are the same height and a bit wider. Anyone have a definate if they will fit or not.....
Also anyone have an idea if the 275/65 would fit (34.00/11.3). Measuring my wheel wells it looks to fit and is no wider than the stock 275/55.
post some pics if you go through with it, I'd like to see the results... :uhoh:
I have a stock suspension avalanche 1500 z-71 with 305-50-20's on it with no leveling kit with out any rubbing what so ever!
The wheels are MOTTO and the tires are Cooper LTZ ZEON with a pretty aggressive tread they are a great off road and snow tire, with great street qualities, ( they are quieter than the Toyo Proxess ST sticky street tire) i would recommend them to anyone
  • 1 month later...
What year is your Avalanche? i have an 07 LTZ 2X4 and I am expereincing rubbing in the rear, on the inner plastic. I just got the Cooper Zeon LTX 305/50/20 on friday.. My first turn out of the parking lot, and heard rubbing. Not sure what I should do now. Down size back to original (275/55/20) or bend the plastic?
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
