Air Intake(s)
K&N FIPK II Part # 57-3021-1 Silverado/Sierra 1999-2004 V8-4.8L, 5.3L (Except 2500 models)
-Used very little, has been sitting for years.
-New rubber mounts from K&N included.
-K&N filter wrap (Black).
-Amsoil DRY Filter (Never used).
Price: <<<$235 OBO + shipping>>>
Airaid MIT used very little, part # 200-912 ---99'-05' silverado/Sierra V8
Price: $ 75 + shipping
Payment: Paypal
Email: [email protected]
Thanks
Payment: Paypal
Thanks
Would you take $75 including the shipping for the airaid mit?
the black tube/elbow looks like it would fit but can see if it goes to an 04 8.1 yukon. definitly interested
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
