Any way of getting a picture of the top of your pistons? It would be cool to see how clean it is inside. Here is one of the #1 piston on our 2016 Suburbans 5.3 with 114k miles on it. Just use BP 93 and when I can E85 with the occasional AMSOIL P.i. use.
Some updates after living with this cover for a couple weeks....
- Paddle latches are great. They should be rolled out across the Realtruck line.
- My cover may be taking on water. We had a hard rainstorm the other night and the next morning when I opened the cover, water poured out of the plastic spring housing mounted to the underside of the second panel. Not sure how it got in there but I think it's getting through the seam on the outside above the spring. Sent pics to Realtruck so their engineers can look at it.
- Tightening the rail clamps a little tighter seems to close up the gap between the rail and the truck cap. That has helped some of the leakage I was seeing.
All in all - pleased, although I'm wondering if I got a dud with the water leak issued. Stay tuned.
