Hvac Controls
Is it possible to swap out my dual climate controls for the Auto set up ?? or does it require a different harness and BCM ?
Heater Control
This is exactly what you are looking for. It takes alot of work.
Heater Control
thanks.. yea i think ill just turn the fan down on my own :uhoh:
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
