Leaking Trans Cooler
my trans cooler lines are leaking but i haven't found any sign of where the fluids going..no spots on the ground at all...any ideas? is this common on the 1500s during the mid 2000s?
When my cooler lines leaked they would drip on the exhaust and most of it would burn off.I didn't even notice much other than a little burning smell at first. then I noticed a little smoke in my mirror at stop lights.Then I changed them before they completely went.
thats what i'm thinking, is this a common failure? i don't have any spots under the truck but i do get a nice aroma when its idleing
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
