Leveling A 2wd
hey guys, just wondering if there is an easy way to level out the front of my truck (94 sierra 5.7l 2wd). My front shocks we're finished so I changed them and it still sits at pretty much the same height. I just want it a bit higher so that it is at least a bit leveled with the back of the truck. I have heard of these coil springs spacers but i'm wondering if they actually work and if so how much they cost. any help would be great, thanks
I have coil spacers from suspensionmaxx.com
Here's some pics:
In that pic. I had just put them in the day before, and they actually measured about 3/8" higher in the front, but now they have settled in, and it measures perfectly level. Here's the LINK to the spacers I got, and now they're only $42, I paid like $75 a couple months ago. As shown in the pics. they go under the springs, and they are made of cast aluminum, so they are very durable and won't wear out. I installed them myself, I was thinking you would need a spring compressor, but you do need to drop the lower control arm. This requires removing the bottom shock bolts, the sway bar link, and the 2 large bolts that hold the control arm on. If you have some skills, you should be able to do this, but I will say, it isn't exactly an easy task.
I also looked into the polyurethane kits made by Daystar that mount to the top of the springs, and they are almost $150, and I wasn't to sure if I wanted the plastic ones, so I opted for the cheaper aluminum spacers.
If you have any other questions, let me know and I'd be glad to help you out, and if you need any other pics. let me know, and I'll try to get them asap
ok thanks a lot man, that really helps, I think I should be able to do it by myself, if not then i'll just bring it in somewhere but I think I should be ok. Your truck looks great by the way
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
