Mirror Cap Replacement
thin screwdriver with tape and slowly and GENTLY and install new one once old one is off...
I was told to remove the upper and lower part of the Mittor then take the top off and pop both back on as one then you do not need the screwdriver and that is what I did and it was a piece of cake no problems , just pinch it at the bottom next to the door and pull should come right off.
So I do not need to remove the mirror(glass) at all? don't want to mess up anything...thanks guys!
I would really appreciate any pics if you have them, just to see where I need to pry slowly...anyone?
ok, just got them delivered to my house, maybe I will try and do a "DIY" with pics..hopefully I don't mess it up. thanks yall for the input
it's really easy. just did it with my truck.
and the door handles.. they were a couple more steps to replace them :noway:
be a little careful on the mirror caps because the clips are really easy to break off..
all you do is pry them up like you would any body piece (using a flathead screwdriver or something flat) and then just pull the top apart all the way around and then slowly around the bottom (depress the clips down so you dont break them off)
hopefully that will give you some idea. sometimes you just gotta rip into it and do it yourself.
Here's a pic with the cover off. I don't know if it will help or not, but as others have mentioned, it is an easy process. Just take your time if you don't want to break any of the tabs from the old covers. I broke almost all of the tabs on mine, but I didn't care because I was never going to use them again.
thanks guys, I was able to install them and I only broke one middle tab on the old ones so they are fine....
They look great!!!
does anyone know where to find the color matched door handles for an extended cab?
They look great!!!
Not sure of the color from your sig pic, I think this is it. But keep your eyes on e-bay.
:noway:
Ebay Link
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 1,046 Guests (See full list)
