Tow Hook Hardware
I have an 09' 1500 that didn't come with tow hooks, but I picked some up for it, but only the hooks, no hardware. Does anyone know what nuts and bolts I need to install them. I'll get them from the local hardware store, just not sure what to get. Material, sizes, what do I need?
I would think you need to get the hardened bolts of the proper grade. What you find at the hardware store is not beefy enough for this application. It looks like the GM accessory hooks come with mounting hardware...
Only picture I could find.
Bolt PN 11609610 for about 2.50 each
Nut PN 11516078 for about 3.00 each
These are for the factory bolts and nuts. Hope this helps...
I installed a grille guard in my truck, used the factory bolts and tow hooks, but I have the bolts and nuts that came with the grille guard if you are interested...
The nuts are more expensive than the bolts? That's insane. Go to a nut and bolt shop. Get some grade 8 stuff and call it a day.
I would just go with a grade 8 bolt and nuts that fit. Probably much cheaper IMO. If your not sure the grade of the bolt, grade 8 bolts have 6 lines/marks on top.
I have my OEM tow hooks and hardware, if you want OEM that bad I'll sell em to ya. Or you can listen to Brims and me and go get some grade 8 bolts. Pm me if your interested in the hooks.
that's what I thought too. Good ol GMpartsdirect pricing!
I'll prob go to the hardware store this weekend and match some stuff up.
Here are the specs on the bolt and nut:
Bolt
BOLT-HFH,M12X1.75X120.9,44.75 THD,26.6 OD,10.9STL,GMW3359,REDUCED BO(FRT TOW HOOK)
Nut
NUT,HFH,M12X1.75,14THK,25 O.D.,10,PZOR(FRT TOW HOOK)
Now, if this doesn't help then I am out of ideas!
Yes, you definitely need at least grade 8 bolts for mounting the tow hooks. Grade 8 bolts have the ultimate tensile strength of 150 ksi, i.e. for a bolt with 1 inch cross sectional area, a tensile load of 150,000 lbs would have to be applied before the bolt breaks.
The bolts are metric, good luck finding them at the hardware store. . The ones from GM are the right size and strength and are a 10.9 Rating. Grade 8 bolts are good in compression but not always in shear. I think you should use the ones the engineers have spec'd for this application, especially if you're standing beside the cable or chain.
The specs listed above are from the GM catalog.........And in the time we have spent discussing this, ones could have already been sent from the dealer!
