Console Lid Repair
2006 GMC 2500 HD
I've done the forum search and just want to make sure I understand the fix correctly. The part number for my specific need would be 19127364, right?
I have found that part number on Ebay for $145.00 but it's only $87.80 through GMPArtsDirect.com. I assume that GMpartsdirect is a reputable source. Just found it odd that they would be so much higher on Ebay.
I believe I've found an installation walk through with pictures but I don't understand why removal of the console is necessary. Does it just make it easier? http://newseatcover.com/lidrepair.html
Pictures of the lid:
Pictures of the truck:
I have also made similar purchases with no issues....I have found many ebay stores to be higher than other reputable sites in many cases....not surprising.
I just bought Firestone rear air bags for my HD on Amazon for $189....cheapest on ebay was $240 or more...ugh
If you can repair the console in the truck, it would be easier, as the seats have to come out to remove the console...not hard, just a bunch of work....
I believe that you have to replace the entire unit. I know that when mine broke, I could not just order the top. Fortunately it was under warranty and the dealer took care of everything for me.
You better call and ask your local GM parts guy first and ask it that
is what you need before you order it online.
The description on a GM parts site don't seem right and I think its for a model
with a seperate center floor console lid hinge.
Why? Because I also had a broken hinge and broken push button on both
my 01 and 04 gmt-800s. Both were fixed under warranty with a complete
replacement unit.
And as we all know if GM had a $87 hinge only fix instead of a $400 whole
seat console fix which one would they do?
Is this it?
http://www.partswebsite.com/hendrickgm/?i=...imagecallout=10
No, the one in your link is for the full length console. Mine is the jump seat console.
According to this I can just replace the lid:
Document ID# 1851484
Subject: Front Seat Armrest Hinge Breaking (Replace Lid) #06-08-50-004A - (07/28/2006)
Models: 2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2006 GMC Sierra, Yukon, Yukon XL
with Front Split Seat (RPO AE7)
This bulletin is being revised to include RPO Code and interior trim color code information. Please discard Corporate Bulletin Number 06-08-50-004 (Section 08 -- Body and Accessories).
DO THIS
DON'T DO THIS
Replace just the lid for the armrest.
Do NOT replace the armrest assembly.
Condition
Some customers may comment that the lid for the armrest is broken.
Correction
Replace the armrest lid using the procedure below.
Open the armrest lid.
Remove the armrest inner panel. Use a flat-bladed screwdriver and place it between the two panels and pull to separate.
Fold the seat backs to gain access to the hinge pin. Using a punch, push the hinge pin out.
Install the two springs into the new armrest lid.
Align the two springs and the lid to the armrest and install the pin.
Install the inner lid to the armrest and close the lid.
Place the seat back in the upright position.
Parts Information
Part Number
Description
19127364
Compartment Kit, F/Seat Stor (Dark Pewter) (69I)
19127365
Compartment Kit, F/Seat Stor (Pewter) (92I)
19127366
Compartment Kit, F/Seat Stor (Neutral) (52I)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
C2740
Door And/Or Pad, Console Compartment - R&R Or Replace
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
This is a link to the one on Ebay: http://cgi.ebay.com/ebaymotors/CENTER-CONS...=item3efd0e3bdf
GO.................Like I posted I didn't think that part and description didn't seem quite right
and the illustrations look like the floor console.
But from that GM bulletin you posted I guess NOW that you can get just the lid.
My last replacement lid was done in 04 as I see the bulletin date in 06!
Ya need to fold back the seats to have room to drive out the pin that holds the
lid on.
Good to know!
    250.3k
    Old Bay
    Old Bay
  • Who's Online   1 Member, 0 Anonymous, 691 Guests (See full list)
