Exhaust Rattle, Now Engine Light
Last night I started to get a rattle in my 04 Silverado. I have 106,000 and have never had a problem with it. Of course, now that itis out of warranty everything is starting to fall apart on it. I climbed under the truck and it appears that the pipe coming out of the back of my cat has come loose.. can this be welded back together and would this cause the engine light to come on? I need to get this fixed at it is my primary vehicle....
Any help would be greatly appreciated.
Thanks
If the break is before your second O2 sensor, then yes it would cause your check engine light to come on due to causing that sensor to register a reading that it outside of it's normal operating parameters. An exhaust shop MIGHT weld it, but if the break is on the cat itself then many shops won't touch it, unless it is to install a new cat.
Thanks,
I will closer inspect it tonight, but I think it is the pipe going into the cat and not the cat itself.. all I know is that it sounds like it is going to fall apart.. and I hate driving a vehicle that makes all kinds of racket, i don't even care for loud pipes.
I will let you know what I find out.... thanks again for the response.
Got home climbed underneath it and had my daughter start it up for me... Low and behold, it would appear that I have either tossed a rod or spun a bearing. Now all I have to do is drop the pan, find out which one it is, see if the piston wall is scored, see if the connecting rod is messed up and look at the crank. I have driven it about 30 miles since it started knocking.. but, the oil pressure remained up, never got hot, just can't imagine what caused this to happen.. all I was doing was driving down the interstate. But, like everything, the warranty went out 6,000 miles ago :D:D
Now all I wish I had was a garage or a shop I could pull it into so I can pull the pan, cause laying outside on the concrete really stinks! Anyone live in Central Alabama that has a space I can borrow for a couple days??
:lol:
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
