Making A Cst 6" Kit An 8"
I just purchased a CST 6-8" kit very lightly used. The kit is in awesome shape, has the twin tower front a-arms with remote shocks and is complete. It has blocks for the rear (wish it had springs). Here is my question: My truck (2004 GMC 2500hd 8.1/allison regular cab longbed 4x4,3:73's) is currently sitting at stock height and i only want to do this once. CST's website says to make this kit an 8" you need to purchase the torsion keys and that you may need to modify your rear driveshaft. That is all they really say. Do i need to get the extended brake lines and has anyone gone the add-a-leaf route in the rear with the 6" blocks (as opposed to going with a 7" block) I would love to put 8" springs in the rear and be done with it, however i don't know if finances will allow it. Is the rear driveshaft modification definate on this lift and are there any other things that i should be planning on other than a regear to probably 4:56's?
Ideally, i would like to go the full 8" with this kit and put a 3" body lift to clear 38x15.50's. I know everyone says never go past 37's on these trucks, has anyone gone this route with the CST and had good success? The truck will not be wheeled to death by any means. Very light wheeling and not to frequently either? More normal driving and pulling trailer than anything else. Thanks in advance for the help!!!
I can see the different keys in the front, and in the rear, I would normally say skip the add a leaf, but I think 7" blocks could cause axle wrap, which isn't good, so in your case, AAL might be the way to go, but you may notice a bit rougher ride, unless you can get 8" springs. I would say you would need a custon driveshaft going that high, but I'm not sure, and I think the brake lines may need to be extended also.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
