Rear End Pulls Right In Snow
I'm noticing on my new truck that when there is significant scow on the road, my truck in 4hi, rear pulls to right. Is it these duravis M700 tires, or something in the axle? It doest happen in 4hi in heavy rain, or at all in 2hi.
The first thing I'd do is check the air pressure in your tires and make sure they are even side to side.
DEWFPO
Since the truck doesn't do it in 2hi in the snow, that means that 4wd is the problem. Find some dry pavement and put the truck in 4hi and see if she still pulls. If it pulls on dry pavement, the 4wd is the problem. If it drives straight, then the snow is causing the 4wd issue. Due to the design of the 4wd system on these trucks, I think it's the passenger side wheel is the one that typically does most of the "driving". See if the truck still pulls in 4lo. If it doesn't, it's your imagination.
i dont know, what could actually be wrong? what happens different in 4x4 in the rear then in normal 2x2? op, being how bad the north east has got hit this winter, you sure the snow isnt so deep that maybe the front end is slipping a little bit(but still grapping every now and then to move the truck), and the back end is just letting loose even the tid bit? as the other poster said check the tire pressure, as this could be happening. i know in my quad if the back is off even 3psi it pulls a little to that side doing a wheelie. a truck holds alot more air but if this is the case that they are off, its still going to find the weakest link under these conditions.
what are you doing when it happens? plowing?
If the air pressure in your tires is different side to side on an axle it changes the rolling diameter of the tires and can cause a pull. Check the tire pressures first.
DEWFPO
DEWFPO
Rear pressure is 70psi even right and left. Front is 50ps, even.
    mark2
    mark2
  • Who's Online   3 Members, 0 Anonymous, 523 Guests (See full list)
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
