The Queen Mum
Jpshostr
The Queen Mum and how much the Brits miss her
The following are from a message board set up on the internet to honour Her Majesty Queen Elizabeth, the Queen Mother...
"I think that the Queen Mum and Princess Diana are our very own Twin Trade Towers. At last we can look the people of New York in the face".
L.Ward, Mansfield.
"When Diana died I swore I would never smile again, but eventually I did.
Now the Queen Mum has gone I cannot imagine that I will ever smile for the rest of my life, but I will probably break that one too".
A.Christie,Hendon.
"She was one of the old school, all the remaining royals are ####"
J.Clement. Grantham.
"I thought she would never die, she has let us all down very badly"
D.Holmes, Somerset.
"She was a trooper and she never gave up. I remember one time she was visiting a school and I asked her if she would like to make a visit to the cloakroom before she left. 'No' she replied, 'I didn't give in to the Nazis and I won't give in to the bladder'. That's how she was, a fighter,
who refused to be beaten by anything. She pissed herself later though, it was sickening".
B. Forrester, North Yorkshire.
"She was a marvelous woman, and a wonderful lover".
L. J.Worthington, Penrith.
"I am absolutely devastated, at least we could have got the day off".
S.Wilson, Bristol.
"How refreshing to be able to mourn the death of a member of the Royal family without being accused of being homosexual".
J. Fletcher, High Wycombe.
"Her death should act as a warning to others who think it is cool to experiment with drugs".
E. Franks, Cheshire.
"On behalf of all blacks, I send the sincerest condolences".
T.Watson, Ilford.
"Perhaps if we automated her old golf buggy it could still drive around The Mall on its own and bring pleasure to the tourists".
Y. Howell, Slough.
"Once again the Queen is not upset enough for my liking, the woman should have a bit more compassion, how would she feel if it was her mother?"
W.Waugh, Richmond.
"It is such a loss, God has shat on our heads".
K. O'Neil, Inverness.
"I am sure the Queen Mum will not let this setback put an end to her public duties".
N. Wallace, Swansea.
"I hold Princess Margaret in no small way responsible for this terrible event"
E. Thompson, West Lothian.
"Bomb Iraq for us Tony, its the only thing that will make us feel better"
P.McGregor, Southampton.
"We must do all we can, send blankets, food parcels, jumpers, anything to help these brave souls who are queuing up to walk past her coffin".
R. Thompson, Bath.
"I have been unable to masturbate for five days, and will not do so again until her majesty is buried"
E. Gorman, Derbyshire.
"Good God, who is next, Geri Halliwell?".
R. Combes, Romford.
"No matter how she felt, no matter the situation, she always wore a smile. Just like a retard"
G. Hollins, East Sussex.
"I remember she came to visit us in the East End one time. She was so kind, so generous and so sweet. She whispered softly in my ear, 'you know its not true' she said, 'you don't smell of ####'. She was a wondrous person".
E.Collier, London.
"Whichever way you look at it, it just is not as exciting as Diana".
G.Williams, West Midlands.
"She was one of us, and by that I don't mean she perpetrated
insurance fraud or lied about expense claims. She was like us in a good way. God bless you ma'am".
L. Weller, Harlow.
"If only I could get my hands on that fish bone right now, you heartless bastard!"
J. Hedges, Cowdenbeath.
"She had such a difficult life, always battling against adversity and misfortune. Let us hope that if there is a next time round she is given a life of privilege and comfort"
T.D.Wainwright, Hastings.
    • Those are parts changers. It can get expensive though. I was a mechanic for 30 yrs. My truck has made this noise since new. I really don`t know what it is. It really doesn`t bother me. I`m still in warranty but have not brought it to the dealer.   I`m not buying the oil pump prime thing. Screw the TSB. I believe it`s in the trans pump gears. They rattle when that piss poor ULV oil drains off after a while. I believe those sharp tooth gears, with backlash, can rattle when dry. Not a vane style oil pump. Wonder who`s right? Me, or the TSB?🤔   Maybe I`m wrong?
    • Sounds about right. I miss the days of mechanics lol.
    • On the PCM side, blue PCM connector, pin 18, solid gray color (no stripe) wire circuit 435.  That is the EGR low circuit which an issue on that line (be it the wiring, the PCM or the EGR valve or system performance) will trigger P0401 when it tests that code.     There is also a VERY old TSB that states to make sure you clear the DTCs ANY time the PCM is unplugged, reprogrammed, or if the EGR valve is unplugged or replaced as the PCM has an auto zero function in the PCM for the EGR pintle data   61-65-59: SMU - SECTION 6E - ENGINE CONTROLS - CLEAR DTC'S - (Nov 25, 1996)   "CLEAR ANY DTCS FROM THE VCM ANYTIME AFTER DOING VCM REPLACEMENT/ PROGRAMMING, TURNING THE IGNITION ON WHILE THE EGR VALVE IS DISCONNECTED, OR REPLACING THE EGR VALVE."   Some diagnostic aid notes in the GM diag on P0401 for a 1995 S10 Blazer:   Diagnostic Aids Notice: In order to prevent further damage if the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged converter) using the procedure found on the restricted exhaust system check. If the exhaust system is restricted, repair the cause; one of which might be an injector which is open due to one of the following reasons: Stuck Grounded driver circuit Check the oil for possible fuel contamination if a stuck open fuel injector is found. Poor connection or damaged harness - Inspect VCM harness connectors for the following conditions: Backed out terminal BL 18 Improper mating Broken locks Improperly formed or damaged terminal Poor terminal to wire connection Damaged harness Intermittent test - If connections and harness check OK, monitor a digital voltmeter connected between terminal BL 18 and ground while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change.
    • maybe get a service manual off ebay?  or check charm.li (website) or subscribe to alldata.com for it?
    • This biggest difference in a HM oil is in contains some  "Seal Conditioner". DEXOS oils and most shelf oils are "Dry" oils which over time harden seals. "Seal Conditioner" is more times than not, an Ester. Addition will soften the seals over time but will not repair one that leaks or has cracked. Esters also provide some cleaning but these HM oils don't contain enough to solve out hard deposits. Just the soft stuff.  Also a function of an Ester.    Ester's are not 'allowed' as a 'co-base" by license. Weird, right?  A certain amount is allowed as an additive. Bunch of game playing is what it is. It's why HM oils don't have a DEXOS approval.    DEXOS is a license 'with' a specification but is not a specification. Never was, never will be. It's GM's slot machine always paying the house. Use what you like.
