Installed My Magnaflow 16746 Check Out The Pics!
I Finally installed my Magnaflow 16746 before tire, side exit exhaust! The truck sounds like a total beast! Very happy with it. Very very minimal drone inside the car, LOUD when you get on it! Sorry about the dirty truck, we have been having torrential downpours here in the bay and there was finally a chance to take a couple pics with my iPhone. A+ for Magnaflow! :D
Eddy,
looks good, not how about some sound clips if possible???
For sure! Im at work right now, but ill try to record one when I get home!
That looks pretty sweet!!!! What tips are those i really like the way those look!!
The tips were already on the Magnaflow setup, its the one that came with it. The system that I bought was cat-back. I think they are dual 3.5" tips.
I have always loved the way that looks. Had it on my 2001 Silvy and on my current 07. I was sad when i went up to the snow and had to put on some chains... They kept on hitting the tips and mangled them. I since then had to cut them off and put on some turn downs. I still have them on pictures in my garage for the memorries :D
OUCH!! I would have cried LOL!
What kind of car is it? j/k :confused:
The tips look sweet. Will black exhaust deposits build up on the tire behind the exit? Does it prematurely dry out the rubber on the tire?
HAHAHA I meant truck :crazy:
Thanks for the compliments! Ive only had it on since yesterday so no deposits yet?? The tire should be ok because the tips are far enough away and angled so the exhaust shouldnt effect it....but I guess I will see in time.
My setup was simillar with the exception that my exhaust was closer to the tire and a sat flush with the body of the truck and now the bed fender that pops out. I had it on there for a lil over 3 years without a single problem. My tires were in good condition when i changed them. Only reason I changed them was for snow and wet road traction, also cause i wanted something meanner looking. I would do it again if i had the chance to.
So I took a video for a sound clip when I got home last night but I couldnt load it to my host site? I use Picturetrail.com, and I was trying to load it it took a LONG time and gave me errors after a while :rolleyes: Is there a another way to load the sound clip without using a host site?
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 3,038 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
