Question On A Tsb Or Two?
I have found one tsb I need to be fixed. My question is, the tsb on cab mounts for gmt900 is for when steps are added to the truck. Is this a warranty issue or will it come out of pocket. Also I am having trouble finding the tsb on the climate control sensor in the roof of the cab. Any help would be greatly appreciated. Thanks.
If you have GM steps that the dealer installed, they'd probably cover you under warranty on the cab mounts. Otherwise you'll probably end up paying for them.
I figured that. I am making a appointment to have a couple things fixed and was wondering if that could be one of them. O well, looks like a weekend project with a case of beer.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
