Installing Xm Radio Questions
hi
just purchased a 2010 silverado 1500 with standard audio system (not Bose)
I have a portable xm radio i want to install in it (audiovox xmxpress)
I will be using an audiovox fm direct adapter kit. I need to know if i need to buy antenna adapters for the fm antenna where the audiovox fm direct kit will plug in.
also do i need to buy an adapter to use the shark fin antenna on the truck's roof with my xmxpress radio.
would like to have all my parts ready and waiting when i pull my dash. don't want to do this twice.
any help is appreciated
hi
check this link:
http://www.gm-trucks.com/forums/index.php?...p;hl=xm+antenna
dlewis1111
Thanks for your input/help.
not sure that link answers my questions though.
these guys were hooking up sirius units to xm equipped trucks.
i am using an xm unit in an xm equipped truck. i am pretty sure sirius uses a different antenna then xm.
what i am wondering is does my xm radio accept the factory/truck antenna,do i just need an extension to reach it?
also they used the aux input on the front of the radio. i don't want to do this.
I plan to use an audiovox fm direct adapter. it is specifically designed to hook up an xm radio through your fm antenna cable. i need to know if my fm radio antenna and the fm direct antenna are the same sizes or do i need to purchase adapters for them too?
thanks for your help anyways.
anyone else out there ever do this and can give ma a little info?
didn't find much help on this so i started making some phone calls.
Everyone i talked to said you cant hook up a portable xm unit to the oem shark fin radio.
the last place on my list to call was TSS radio. They were very knowledgable and knew exactly what i needed for my truck.
here is a list of the parts required for anyone thet is interested.
fm antenna adapter 40-cr30 = $24.00
single input antenna adapter plug xmtosirius-p = $20.00
the guy i spoke with assured me these parts would get me up and running.
will post back after i hook it all up.
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 859 Guests (See full list)
