Hvac Mode Stuck On Floor
1995 Silverado. HVAC mode is stuck on FLOOR. It was working ok up till a couple of weeks ago.
This is an older electronic control with 3 wires to actuator. I have part of a factory service manual and a Haynes wiring diagram. Control head is DELCO # 15-72267 (GM # 16233143)
I started it up with blower going, temp midrange, laid in floor with flashlight and actuated the MODE control from one side to the other. The actuator linkage did not move.
I probed the actuator signal input (white) with a voltmeter – with actuator connected. With engine and blower running, voltage ranges from 7.74V on VENT, 7.48V on FLOOR, down to 6.7V on DEF. Then took connector off actuator and measured – pretty much the same voltages (unloaded).
This does not seem to be enough range to me so seems like it would be the control, not actuator. I have a service manual but it gives no information on voltage ranges to isolate to control or actuator. What say the experts? Is there another procedure I can follow to isolate? (have not removed the actuator yet to see if it works in my hand).
UPDATE
I removed the actuator, connected the connector and watched the rotation when moving the mode knob. It rotated but only a slight amount, probably not even enough to overcome the shaft lash. I was able to operate the door shaft by hand so it is not stuck. Im assuming at this point i have a bad control head. The slight amount of movement corresponds with the narrow voltage range measured on the control signal. Sure wish they would publish expected ranges for this stuff.
they do at the dealer,when you price out YOUR diagnoses and your wrong ,you will have spent the diag money ,so good luck brother,cross your fingers
I figure even if i end up replacing both the actuator and control head, its still cheaper than taking it to the dealership. (They would probably laugh at me if i took a 15 yr old truck there anyway). I usually dont pay dealer retail for parts either. Just ordered a control head on ebay (new in box OEM delco) for about a $45 savings vs local dealer retail.
If i had to pay labor for every repair to keep up these old trucks, i might as well buy new every few years like everybody else and have perpetual payments. I have another old truck i swap out to drive while waiting on parts and me to get around tuit. I keep it running, registered, and insured so thats another cost i should keep in the bottom line. Its also somewhat fun and challenging to me (im an engineer). Id rather do it myself and save money for retirement or some other toy. Maybe i'll eventually save enough to buy a new truck!
    DLZ
    DLZ
  • Who's Online   5 Members, 0 Anonymous, 632 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
