whats the mileage? when i did my 100k tune up i did the following
plugs/wires
coolant
brake fluid
belts
trans fluid/filter
rear differential(your case front diff also)
i'd recommend transfer case service also, you will need the blue goo from the dealer for the case
plugs/wires
coolant
brake fluid
belts
trans fluid/filter
It has 112XXX. Coolant, brake fluid, and belts are all good.
So plugs, wires, trans, and diff fluids should get it?
plugs/wires
coolant
brake fluid
belts
trans fluid/filter
AcDelco, AcDelco, Dexron, synthetic 75w90.
plugs/wires
coolant
brake fluid
belts
trans fluid/filter
1+ make sure to do the transfer case and both differentials, i'd recommend just a pan drop, filter change, it won't take all the fluid out but flushes are kind of risky for that mileage, i was told by a tech that if the trans have been flushed before at the right intervals then its ok to flush later...your choice, the filter and pan drop is cheaper
