Fs: 20" Factory Chrome Wheels
up for sale is a set of 4 factory Chrome 20" Denali wheels, (these have the chevy logo center cap)
these are the standard 6 lug chevy / GMC bolt pattern and sould fit on any 6 lug Chevy, Truck or SUV.
Tahos, Yukon, Silverado, Suburban, 1500, Avalanche, Escalade etc...
Beautiful condition, no curb damage.
These wheels are super rare, and IF you can find them at the dealer, they are over $1200.00 each!
selling entire set of 4 with center caps for only $1575.00
I am located about 30 miles east of Los Angeles for local pick up, I would also be willing to ship, I have paypal too.
PM me if interested, thanks
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
