Truxxx Leveling Kit
Do any of you know anything about this leveling kit? http://www.truxxx.com/product/chevrolet_gmc Part #: 406035
I have an 08 CC Z71 4x4 and my local truck accessories place is telling me that they love this kit. I have noticed some of you saying not to go over 1.5" on the front. I am new to these kinds of lift and I do at TON of driving so I don't need something that will cause problems. Hope some of you can really give some imput on these leveling kits!!!
This kit works on the new "900" series 2007-08 Chevrolet/GMC 4x4 pickups.
This kit increases the front height 2.5" from stock as well as lifting the rear of the truck 1.25" giving you the clearance you need to run larger wheels and tires or to compensate for the heavy loads used in a working enviroment.
This kit is designed specifically for the "900" series 4x4 truck to make sure it works as GM intended!
Installation of this kit allows for 33" tall tires (16"-26" rims, stock offset) to be used without rubbing!
All of our kits are a direct bolt in, simple and easy to install with nothing more than common hand tools and require no modifications to your vehicle. These kits retain the stock ride quality of your truck. Our kits are made in the USA out of the finest steel and we supply you with complete instructions including install pictures, alignment specs and dedicated technical support.
  • Maintains stock ride quality, no strut disassembly required!
  • Stock shocks can be used
  • Allows for up to 33" tires to fit without rubbing
  • Alignment specs provided
  • Truck can be returned to stock after lease term is up
  • Made in the USA
I wouldn't be comfortable putting in a spacer that big. It will lead to premature ball joint wear etc.
Like you mentioned 1.5" is about the biggest for a spacer to not cause major issues. If i were you and wanted 2.5-3" of lift, go with a body lift. Either 1.5" suspension leveling kit + 1.5" body lift or a 3" body lift.
I have an 07 silverado with the Truxxx leveling kit. It is the 2.5 Frt and 1.25 RR. The kit came with 6- 1/4" spacers. 3 for each side plus a 3/4 inch spacer for under your shock. So its pretty adjustable you can install one 1/4"spacer per side or two per side or all three and each will give you different amounts of lift. The 3 spacers measure .75" added to the .75" of the shock spacer combined is only 1.50". but it gives 2.50" of lift. I have drove 13,000 miles since late Oct when I installed the kit. I have not had any trouble with it. Just got back from a 1400 mile trip and the truck drives good. I am also running the 275-70-18 goodyear Duratracs.
I have put 44k on this kit...82k total on the truck and haven't had any issues yet.
its way more llft than most people would suggest to run with the leveling kit... 1.5" is safe, 2" is probably as big as I would ever go. I duno though I havent had a leveling kit for that long. I ran one on this truck before the lift for about 10k. it was a 2"
    KirbyCo
    KirbyCo
  • Who's Online   6 Members, 0 Anonymous, 1,514 Guests (See full list)
