Replacing Starter On A Boat - Need Help, Does Not Have Power To Anythi
Mossyoakglock
I just replaced the starter on our boat. It's a '90 Commander 200 FS w/ 4.3L (Yamaha or Mercruiser, can't remember now). We had it rebuilt since we couldn't find one around here, plus it was cheaper. I would assumed that replacing the starter on a boat would be the same as a truck/car since it's a GM 4.3L V6. Can somebody take a look at the picture and see if I have everything connected properly. It's not the best picture, but it will do for now.
I have one wire running from the positive terminal on the battery to the 12V post on the starter and there are two other wires that are connected to the same post that run up to the starter relay/solenoid. There is a smaller yellow/red wire that is on a smaller post behind the red wires that you cannot see, and the negative cable is running from the neg. terminal to the block for the ground.
My new problem is that I have no power to anything, not even instruments, lights, depth finder, etc and obviously it won't turn over or click. Does everything look like it's connect correctly? Could a fuse or something have been tripped causing it to not have power?
Thanks in advance!
Cant offer much help from the pic you posted, but if you had the battery connected while changing the starter then you need to check all your fuses. Also check the battery and your grounds. Could also be bad connection at battery with either cable/post.
Hope this helps.
Hope this helps.
Everything was disconnected when changing the starter. It was disconnect for a few days while the starter was being rebuilt. The starter worked before we removed it, we just had to hit it with a hammer before every start. I didn't remove any of the grounds either but they were all good before the originally starter was removed. I'm gonna do a little more trouble-shooting this week and see what I can find.
Just curious, but why not? My buddy used to have an old jeep that would die in a mud hole and wouldn't start so he would just give it a good hit with a hammer and then it would start back up. We did this for years because he was too cheap to buy a new one.
The first time we gave the boat starter a tap, it was a light one just to test if that was it because originally we thought it was a solenoid that was the problem. Once it started, we realized that it was the starter and not the solenoid, plus the starter was 20 years old.
I don't think it matters that we hit it with a hammer since the literally replaced everything in the starter. The only part from the original that's left is the outside housing.
Magnets don't get replaced at most shops. Hitting the starter will crack them. Once one breaks loose at a later time, it is no go no matter how hard you hit. Dead in the water...literally.
Thats funny right there! :P
I'm sure they would have checked them when they had it apart and if they were cracked, they would have replaced them. They tested the starter when they finished and it worked. I haven't tapped the new one though. I would think that a cracked magnet would prevent the starter from working, but would that prevent the whole boat from having power? Like I said before, we have no power to anything (running lights, radio, bilge, blower, etc.).
I once had a 5.7 marine engine which would not always power up and it had a relay that was bad. It was a small black box type device in the engine bay. See if your engine has one. Also check your safety tether(sp) switch and neutral lever and switch.
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 289 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
