2007 Sierria 5.3 Oil Fill Neck Leaking
Working on an 07 Sierria which is way out of warranty milage wise. Has the 5.3 liter. When doing a service on it i noticed the passengerside valve cover was covered in oil. After futher investigation I found the oil fill neck was coming loose and the oring was popped out partially. Ive never torn into this before. How is the neck retained in the valve cover? Will it require removal of the valve cover to install a new Oring?
it twist in and locks in place. it can actually be removed and the oil cap can be fitted directly in it's place (but it's easier to add oil with the filler neck)
Would this be possible in my case? My filler cap is really hard to get off. I can twist it about 25 degrees then I have to work it to turn more, even then its still a pain to get it unstuck.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 356 Guests (See full list)
