Fog Light Install
Hey Guys,
I recieved my new fog light kit for my 09 Sierra.
I installed it per instructions that came with the kit,however the lights won't burn.
Does anyone know if there is a fuse that needs installed somewhere or something I am missing.
Any responese will be appreciated.
Thanks
John
Hey Guys,
Thanks
John
You sure you connected the wire to the correct terminal in the bulkhead? When I did mine, the image was a bit hard to understand. Verify that there is a relay in the foglight spot as well. Mine went according to instructions and worked right away.
Hey Guys,
Thanks
John
Hey Doug,
Thanks for your answer-It worked just like you said-Like a dummy I installed the pin in B1 rather than B5 as the instructions said. I guess I was looking at X1 from the wrong end.
Thanks again
John
Hey Guys,
Thanks
John
Hey Doug,
Thanks again
John
I looked at the pic for a long time (seemed like a long time at the time) before seeing the two bumps at one end of the connector. Once I saw that, it was easy to tell where to put it.
Hey Guys,
Thanks
John
Hey Doug,
Thanks again
John
Yea, that's how I figured out how I screwed up.
John
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
