Finally Got The Km2s
I went by the tire place yesterday to get them aligned. There price is 45 dollars, which isn't bad at all. But the mechanic I talked to said that if the truck has never been aligned before he will have to take apart the control arm and remove something so it can be aligned? It would be an additional 60 dollars a tire. Is this true? I've never heard of that?
  • 3 months later...
Yes they have to knock out part of there the control arm attaches to adjust the camber. The dealership wanted 79 for mine to do the entire alignment.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
