Coolant Loss
RaddHazzard
2006 5.3L How much coolant will come out when i remove the thermostat?
A gallon of pre-mix and you'll be fine. You should only lose a quart or two. Remember to depressurize the system first, or you will lose a lot more.
Also this is a very good time to do a system flush and fill.
Thats what i plan on, a full flush. Im gonna take out the thermostat, take off upper rad hose and rig a funnel into the upper rad inlet. Start her up and pour in distilled water for a while, then pour in coolant mix. Then i realized i would have to replace the thermostat and was wondering how much of my new coolant i would loose.
I always pop the thermostat out to do a flush...you want max flow through the engine for a flush. I just make a paper gasket for the neck and install it do a flush without the thermo, than use RTV on the neck when I install the thermo and fill the system with new fluid.
If you have one of those stupid first gen thermostats, the kind that's built in the neck, you can bust it open and get the center out to do the same.
I have used all kinds of flush, and just plain old hot water...both work well...I usually only use the chemicals if it looks particularly dirty, or has a scale built up.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
